Solved by iainsavage. Go to Solution.
Solved by L.Maas. Go to Solution.
Louis
Please mention Revit version, especially when uploading Revit files.
I checked all cases . i uploaded small portion of file . its version is 2024
The family contains imported geometry and in your 3D view you have imports in families disabled.
Fixed .... Thank you . The other Families were not wireframed when this has been not ticked .They are imported too
You perhaps misunderstand.
All families are imported into your project.
That particular family however has another family imported (nested) into it.
I've also noticed that the material in the family and the project has transparency applied to it:
Result when Imports in Families are active and transparency is removed from the material:
