Showing Future Phases
Anyone have any input on how to show Future Phasing with Revit's Limited Phasing manager?Also if anyone has any examples of how they achieve a Future-ish Phase would be great.
Thanks in advance
Replies (19)
L.Maas
This is just not how the phasing tools work. You are limited to the new, existing, demolished and temporary.
That said I never had a need for future phasing.
If you really need to do something in that respect I think you could add a project parameter to the relevant families (e.g FuturePhase) and then use view filters in combination with graphics overrides
Louis
Please mention Revit version, especially when uploading Revit files.
I guess I forgot to mention that, that is currently how I do it, Using a Shared Parameter/ View Filters. I guess I was trying to see if there were other ways on how to do future phasing.
RobDraw
How about utilizing the new phase as future?
Rob
I have attempted that, but my Engineer hates that they look like a demolition item.
1.  If you only need to present them on sheets then you can place two views, one is the current phase view and the other is the future phase view (only show future items) on one sheet.
2.  If you need them in one view, put all future items in a different workset, and use View filter criteria based on the workset name.  It is similar to using parameter to filter, just a little bit easier and better for the long run, when you need to actually move them to the future phase.
JOHN.SZLACHTA.JACOBS
Autodesk still needs to add a Future Phase to the Phase Filters. Been a request for many years now.
WFTDesign
TELL ME ABOUT THAT!!!!
I have submitted Revit Idea and attached my Revit file on that idea. So they can play with my file like a toy.
Here is link: https://forums.autodesk.com/t5/revit-ideas/add-future-category-for-phasing/idi-p/8552085
Here is link to my Revit file, so you can play that file like a toy: https://a360.co/2DD0mrD
Please, may I have your vote there? 😄
WFTDesign
Yes, that is what I thought so, too and I would do that. But not a perfect solution.
Here is the link: https://forums.autodesk.com/t5/revit-ideas/add-future-category-for-phasing/idi-p/8552085
Here is the link to my Revit file, so you can play that file like a toy: https://a360.co/2DD0mrD
RobDraw
Good luck?
Rob
I created a new Phase Filter and named it "Show Future + Existing".
Set the Filters as:
New = Overridden
Existing = By Category
Demolished and Temporary = Not Displayed
Then I changed the New Graphic overrides to show new as grey dashed lines and set my views to the "Future" Phase.
s.borello
Great idea... voted!
mroble
I have gone and created a Shared Parameter named "Phase" and, pretty much applied it to all modeled entity categories in my template. I can then create items, they all have the Phase Shared Parameter applied to them via project parameters.
I go and assign that parameter on everything 1, 2, 3, A,B,C, whatever (only on projects that involve phasing, mind you)... And then I can make a filter that can allow me to show, not show, make hidden, make phantom, make red, blue, brown, whatever, it opens up a lot of options.
The downside is, you kind of have to babysit this, because as you add more and more content to your model, you need to make sure EVERYTHING is assigned a phase in this regard, but the pros are that it leaves you with a bunch of representation options.
michaelburke1114
I just had a similar request from the Project Engineer; show the "Future" columns on the graphical column schedule. I ended up:
-creating a "Future" project phase
-creating a new phase filter "Show New + Future" set to New=overridden, Existing=by category, Demolished=Not Displayed & Temporary=Overridden
-updating the graphic overrides for the "Temporary" phase status overrides to hidden
-set both column phases to "Future" (phase created & phase demolished) & added a comment "Future Col"
-modified our column tag to be able to show just a comment
-tagged the future columns in the graphical col schedule
-set both graphical column schedule phases to "Future" (phase created & phase demolished)
-to see the future columns in 3D: set the phase filter to "Show New + Future" & the phase to "Future"
travisdehart
Bump: This thread asking for a future phase in Phasing Graphic Overrides has been circulating since 2017. It's now 2023 and we still don't have this option.
RobDraw
Were you expecting it to happen? I don't think it was ever stated that it was placed on a future phase for development.
Rob
You can now show future phases via view's filters.  Filter by phase were introduced after this topic and the marked solution above.
bdowney
As I have experienced it, there are two issues at hand here, first simply viewing the future phase on a sheet is fairly simple by setting your view to the Future Phase and set the Phase Filter to also show the previous phases.  The second issue as I understand it, is to be able to edit a view within the New Phase while simultaneously displaying the Future Phase as a reference.  The best work around I've seen on this is to create a not-for-plot working sheet and overlay multiple copies of the same plan so that one can be set to future and the second is set to new, but this creates other issues, and it would be better if we could create a Phase filter for a view set to the New Phase to also show Future Phase elements in the same view.
amacomberGH6MU
Care to elaborate on how that works or maybe a link to a help file that shows how to do the filter by phase?
Example:
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
