Revit MEP Forum
Show cut section of piping families
3 REPLIES 3
jan.appelgryn
286 Views, 3 Replies
Good afternoon, when I have a Piping family and I cut through it, it shows the family still in total. is there a setting to show the family that it is cut. If you cut a pipe, it shows only the part that is not cut.
In the image I have remove the lines in the one fitting in the red box to show that I mean, the section is taken on the centerline of the pipes and fittings.
Labels (3)
3 REPLIES 3
hmunsell
in reply to: jan.appelgryn
2 things....
  • what is the family categorized as?
    • if its Mechanical Equipment, in 2022 and older, it wont show a Cut section of it, only the whole element. i believe they added that functionality in 2023.
  • How was the family made?
    • was it made to show the inside, or was it just a solid extrusion?
Howard Munsell
jan.appelgryn
in reply to: hmunsell
Good morning @hmunsell
Thanks for the reply,
1. It is made as a Pipe Fitting, Bends, Tees, etc.
2. Some have inside, some have solid and extrusion or sweep,
3. It was created between 2014 and 2022, only upgraded to a new version each year.
Regards
Jan
iainsavage
Forma Design Contest
