Setting up an own circuit numbering
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Could someone tell me, please, if there’s any possibility of setting up my own way of circuit numbering? The circuit number that I want to get, should consist of 3 numbers, where the first number will indicate the type of a circuit (lighting, 1 phase outlets, 3 phase outlets etc.) and last two numbers will indicate the circuit sequence number of the each type.
For example, the first number for lighting circuits will be 1; for 1 phase outlets – 2 and for 3 phase outlets – 3, so that:
Lighting circuit nr.1 will become 100
Lighting circuit nr.2 - 101
Lighting circuit nr.3 – 102 etc.
1 phase Power circuit nr.1 - 200
1 phase Power circuit nr.2 - 201
1 phase Power circuit nr.3 – 202 etc.
3 phase Power circuit nr.1 - 300
3 phase Power circuit nr.2 - 301
1 phase Power circuit nr.3 – 302 etc.
I have figured out that I can assign a code for different type of circuits (1 – for lighting, 2 – for 1 phase outlets and 3 – for 3 phase outlets) by adding Load Classification Abbreviation to Circuit Naming Scheme, but then I need a circuit numbering that begins with 00 (those last two numbers) and this circuit numbering should start from the beginning (from 00) for each circuit type that is having a different code, i.e. Load Classification Abbreviation.
Thank you in advance.
