Hello everyone,
I'm trying to set the visibility of pipes according to its "piping system" via "Graphic Overrides".
A colleague of mine was able to set it and apply a solid color for a "piping system" in her project but it doesn't work perfectly in mine.
Project A - Working ! solid purple color for the pipe.
Project B - Not Working! Purple lines instead of Solid color.
I tried checking visibility graphics, filters & discipline and this didn't work.
* I prefer using this method to colorize pipes instead of creating filters.
* Im using Revit 2021
Thanks!
Solved by iainsavage. Go to Solution.
Solved by dbutts7. Go to Solution.
Can you share an example for us to take a look at?
Colors can be set by system (my preference) but can also be overridden by filters and materials, depending on how you are presenting the view.
thanks - David B.
David A. Butts
Virtual Design and Construction Manager - Kimley-Horn
Revit Certified Professional/Autodesk Certified Instructor
Revit, AutoCAD Architecture, MEP, Plant 3D, BIM Collaborate Pro Subject Matter Expert
Thank you David,
I looked a little deeper inside the pipes and it seems that a filter was controlling the pipe color and not the piping system.
Do you know if its possible to set a solid fill color to the piping system instead of just setting up the lines color?
Your Pattern = Solid refers to the line pattern so the system pipes will always display solid (continuous) line pattern and this will prevent the hidden line settings in views from working properly. It does not affect the fill pattern for the pipe.
The fill pattern is based on the material HDPE
The fill colour will only appear in views which are shaded or consistent colours or realistic, it won't appear in hidden or wireframe.
I use the material. I added material definitions to my template for all of the ANSI pipe colors and then used a solid fill for the pattern. That way, when you go to a shaded view it shows the pipe by that color.
David A. Butts
.....fills applied using view filters will however appear in hidden line and wireframe
