Scopebox
Scopebox
yoosafshajeeb
Scopebox
yoosafshajeeb
Hello, friends
Pls.find the attachments.
I have created a scope box . But not showing in properties .
Help me pls.
hmunsell
I can't think of a reason that the scope box wouldn't be listed if it is in the model.  i did a couple tests (phasing, worksets, design options, etc...) and it always shows up.
I see your Survey point and Project Base Point are grayed out, which would indicate to me that you are using links? was the Scope Box placed in a Link or live in the active model?
Howard Munsell
You viewport has a custom crop. Turn on the View Crop Region and Reset Crop.
jessem5CN9L
I see you've also got a view template applied to the view. The view template might have NONE set for the scope box, so you may not be able to change it in the properties menu.
Try changing the scope box in the view template and see that that does for you. OR uncheck Scope Box in the view template so it will be activated in the properties menu.
yoosafshajeeb
