Schedule with wall information for devices mounted on walls
Message 1 of 13
Hi All,
I'm trying to create a schedule of electrical devices, which lists the family and also the wall details of the wall which the family is hosted on.
For example if an outlet is mounted on a pre cast wall, the schedule will tell me
GPO01 ---- PC01
Where PC is the abbreviation the architect has used to label their precast walls, and GPO01 is the name of the power outlet. The architectural model will be linked in the to the electrical model that i'm working on.
Is this even possible?
Thanks.
Replies (12)
Message 2 of 13
ennujozlagam
can you share the file so we can troubleshoot?. thanks
Message 3 of 13
Hi, I was talking about this in a general sense. can we extract the wall info for any type of family that has been mounted on a wall?
Message 4 of 13
ennujozlagam
correct me if i'm wrong in my understanding? you need to assign type mark (number or text) so that you can extract it to your schedule? thanks
Message 5 of 13
So the architect has "Wall" families that they've used to model this building. These families have a parameter which define what type of wall they are (eg- PC - Pre Cast Wall, PB - Plasterboard etc.).
I've linked this architectural model into my electrical model and have placed electrical devices on these walls. In this electrical model i want to create a schedule with all the electrical devices and the wall type parameter from the linked architectural model next to it.
By doing this, i know that the GPO 01 is on a plasterboard wall. GPO 02 is on brick work. etc.
I hope this makes sense.
Message 6 of 13
ennujozlagam
you can also  add the type mark in the link file by VG > revit links > custom > set all model categories/model annotations to custom > go back to the views. select the wall  and add type mark, if they are the same type of wall you can add type mark once and will update automatically with the same type. thanks
Message 7 of 13
Thanks for your reply. Unfortunately i don't think the solution you've provided achieves what i want.
If i break my question down even further,
How can i make a MEP family know a property on the wall which its hosted on?
Is this possible in Revit?
Message 8 of 13
ennujozlagam
is this something like this? thanks
Message 9 of 13
iainsavage
@Anonymous Doesn’t want to tag the walls. They want to include the host data in a schedule with the electrical fixtures.
Message 10 of 13
Mohamed-Nassar
you can't get any information in Panel schedule but using normal schedule to get another info and use filter but don't miss to check Boolean icon from linked model
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Message 11 of 13
L.Maas
No, a electrical device has no information on which element it is hosted. So out of the box you can not do this.
The solution would be to add a (project) parameter to your electrical devices that holds the relevant data of the wall (wall number/name), which you then can use to schedule
You can automate this by using Dynamo. It should be possible to write a script in Dynamo that will check on which element the device is hosted and then write the relevant data into a parameter of the electrical device.
I have similar requests to this, that is why I added the IDEA OF INHERITANCE PARAMETERS.
However it has not got many votes so it does seem not to be an issue affecting many users
Louis
Please mention Revit version, especially when uploading Revit files.
Message 12 of 13
Mohamed-Nassar
This information should be in the Structure model
Message 13 of 13
Mohamed-Nassar
and may u need to Bind This Link in the model also
