Revit MEP Forum
Scale light switch in the electrical lighting plan
4 REPLIES 4
JulianPLH58
192 Views, 4 Replies
Hello All.
As you can see here, the lighting switch is small, How can scale it without modify the 3D model?
When I click on it, it does not show the scale command.
Thanks in advance.
4 REPLIES 4
in reply to: JulianPLH58
The symbol should be an annotation family nested in the light switch family.  Look at an OOTB family se how it is done.
JulianPLH58
in reply to: ToanDN
Thanks bu I can't see in the Edit family section the annotation symbol.
apjones
If it is an annotation symbol, you will only see it in plan, not in any 3d views.
Pete
>Please Accept as Solution and give Kudos as appropriate to further enhance these forums. Thank you!
fabiosato
Can you share the family?
Fábio Sato
Forma Design Contest
