Sample MEP Revit File
geteway2digitalindia
I am looking for sample MEP Revit files having all disciplines - Plumbing, HVAC, Fire, Electrical & ELV.
Also how can I view each discipline in 3D by de-activating other disciplines...
RSomppi
Revit used to come with sample models. If they don't still make them, you may be able to find older ones. As far as samples from users, that is something most would not share but there are some here who may be willing and able to help with that if you are lucky.
You cannot directly turn off disciplines in their entirety unless they are in separate models. There are a number of ways to accomplish what you want in a multi-discipline model by turning off the categories that you don't want to see.
Tom_Kunsman
Revit 2024 has some good example models - the Snowden tower project. Not sure about Fire, but does have everything else.
Easiest way to view discipline is by worksets. The other option would be to just set up 3D views (named correctly) that just have what you want to see turned on, and everything else turned off
CAN YOU PLS GUIDE ON HOW TO TURN ON / OFF..
Tom_Kunsman
Sorry, I am not sure I understand your request.
