Room Separation Lines Too Close Together Causing Empty Areas
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am having to create a Room Occupancy Capacity Report and the client only sent me PDFs to use. So I am basically tracing the rooms with Room Separator lines to create my rooms. Now to create this report I need to first draw an overall "room" which is the entire floor and give it a certain occupancy. Next I have to draw out the rooms, but when you draw a Room Separator "area", ROOM 002 inside of another Room Separator "area" ROOM 001 that new area SUBTRACTS from the other area... see "Image 1".
THE ISSUE is when I put in another room, if two of these separator lines are closer than 10" from each other, it causes an empty area... see "Image 2 and Image 3" (empty area in white).
This is happening all over my drawing and I NEED those small areas to be calculated. Does anyone know how I can fix this?
