Revit MEP Forum
Rise drop symbols disappear and appear randomly in Revit
19 REPLIES 19
Message 1 of 20
1332 Views, 19 Replies
Is there a fix for rise/drop symbols randomly disappearing? Workarounds are not acceptable.
Current incident ID: 139689
Projects are being submitted with information missing from the drawings and this not acceptable.
19 REPLIES 19
Message 2 of 20
RobDraw
How can random be fixed? The problem needs to be repeatable in order to find the cause.
Rob
Message 3 of 20
in reply to: RobDraw
So it's acceptable that a product (paid) is not capable of completely performing all it's functionality?
Message 4 of 20
dmiller_SCE
I have also experience the randomness of the riser symbols disappearing. The only fix that I have found to work is to select the pipe and move it vertically and then move back to pervious height and the symbol reappears. The symbol appears even thought the pipe is at the same elevation as previously.
Message 5 of 20
RobDraw
I think that's a completely different topic.
Rob
Message 6 of 20
in reply to: dmiller_SCE
I've also noticed if I change the associated level, the riser symbol will come back, but trying to do this for every level on a high rise could time consuming, and they might disappear again........
While replying, I fixed one riser, synced, closed and reopened, and the rise symbol is gone again.
Message 7 of 20
RobDraw
Have you tested if they print when not shown?
Rob
Message 8 of 20
Yes, that has been test, the missing risers do not show when plotted.
Message 9 of 20
RobDraw
Do they just as randomly come back if left alone?
Rob
Message 10 of 20
Based on my experience with the issue, I have never seen them randomly come back if left alone.
Message 11 of 20
kadmonkee
pipe symbols relate to the cut plane in some cases if the Pipe Rise or Drop does not cut through the space completely it might be stopped below the cut plane and cause the disappearing symbol issue.
confirm your Segments and Sizes are associated to all the scales you are using and your Pipe Fitting and Rise Drop symbol size is set.
are you using any phasing for the design? phase created in will cause this behavior too.
without adjusting your Pipe Rise /Drop in the model try changing your display visual style from fine to course and back to see if that impacts things as well
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 12 of 20
in reply to: kadmonkee
Unfortunately I have already tried all those suggestions.
I also tried changing the annotation scale size in MEP setting and then changing it back, but nothing seems to help.
Message 13 of 20
dmiller_SCE
I believe that I am experiencing the same problem. I have manipulated all settings possible to get consistent results but I still get them randomly disappearing. Here is an example shown in the screen cast. Notice that all of the pipe are the same size, elevation. Also all are from the same reference level. Some of the risers do not display. Only fix I have that works is to move the horizontal pipe down and then back to the original elevation.  The pipe or riser is not sloped, and no plan regions. What is ironic is that the risers right next to it shows.
Message 14 of 20
That is the exact problem we are having. When you sync, close and reopen, dose the rise symbol disappear again or does it remain?
Message 15 of 20
dmiller_SCE
Almost always goes away if I close out and open back up. The pipe will still be at the same elevation and no other users would modify the elements.
Message 16 of 20
RobDraw
What happens when the view is duplicated with and without detailing?
Rob
Message 17 of 20
Good question, I'm reopening the project now to test that out.
I just recently had an issue in 2018 on another project where the view was just not correct, it was showing another level completely. I duplicated the view (with detailing) and everything was fine.
EDIT: Duplicating the view didn't do anything.......
Message 18 of 20
dmiller_SCE
On the views that I have problems with, I get the same results with duplicating with or without detailing. IF I close the file and open it back up the risers will disappear despite me fixing them and they clearly show before I close out.
Message 19 of 20
One of our clients is still experiencing this very same issue (Revit 2019.2):
The parts circled in red should show pipe rise symbols.
In their case it can be quickly fixed by pinning and then unpinning all pipe fittings in the project.
However, the issue returns after only 2-3 syncs with central.
It does not seem to be resolved in 2020.
Any update on resolving this issue Autodesk?
Message 20 of 20
I know it doesn't solve the issue, but at least Adesk's aware of it and working on a resolution, according to:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Maxime Sanschagrin
BIM Director
Pageau Morel
