revit to autocad export
jmendezicce
jmendezicce
You can export files to autocad revit with a template?
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
Si esto ayudó a resolver su problema, recuerde "aceptar como solución" para ayudar a otros a encontrar respuestas.
Matt__W
You can set up one or more custom exports to set layer colors, linetypes, etc for each category in Revit. But if I understand what you're asking, you can't use a DWT with pre-defined layer colors & linetypes to export from Revit.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
jmendezicce
thanks for answer,
i have a project in revit mep with 32 sheet, but when i export to autocad i have a multiple file, with multiple reference, can i have minimun reference in minimun dwg file?
thanks
fabiosato
When you export, uncheck export views on sheets and links as external references, like in the image
Fábio Sato
jmendezicce
hi Fabiosato
i have some many blocks or reference when i export from revit arquitecture file, i want to know is one way to have 1 dwg with all sheet in my revit mep project.
thanks for answer
Matt__W
Revit won't create a single DWG containing multiple sheets. You'll have to use a custom program to do that. Check out this post for a program that will allow you to combine multiple DWGs into a single DWG.
Matt Wunch
Twitter | LinkedIn
