Revit splitscreen issue
afosterEMJBQ
Message 1 of 11
afosterEMJBQ
Hello all. This is my first time posting and I'm not sure this is the correct forum for this question but I'm stuck. Best way to describe the issue is to show you. I have an ultra-wide 35" monitor and when using Revit in full-screen everything works great. When I work with a split-screen setup (picture beside picture) the bottom quarter of the screen is dead space. See images below.
Good.
Bad.
Any help is appreciated.
Cheers.
Replies (10)
Message 2 of 11
iainsavage
Can you grab the bottom edge of the window and drag it down?
Or change the aspect ratio of the window?
I don’t think this is a Revit issue, I think its more likely to be your pc video settings?
Message 3 of 11
hmunsell
Looks like a resolution issue? Are there settings for resolution or screen size with you do a split screen?
BTW... jellous of the 35" screen 😁.
Howard Munsell
Message 4 of 11
Secttor
Hi @afosterEMJBQ
Windows 10 should handle such request.. drag one of those 2 windows (revit or the other one) to the side of the screen..will snap & split in half in order to allow the other one to move on the other half of the screen.. very similar with ordinary explorer windows.
you can tell us also the resolution
Revit MEP - Electrical Certified Professional
Revit MEP - Mechanical Certified Professional
Draftworks.wordpress.com
Message 5 of 11
justin.jollyJ4XVN
I experienced the same issue in Revit 2019. Also the text and the icons were blur. It got resolved once I restarted the computer.
Message 6 of 11
HVAC-Novice
What version of Revit? there was a year when Revit started supporting 4K.
Does the regular windows split screening work (where you drag a window into a corner, or to one side)?
Revit Version: R2026.4.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
Message 7 of 11
Maksim.Melnikov.BY
Hi
Has a solution to this problem been found?
Faced the same when using an ultra wide monitor.
Maksim Melnikov LinkedIn | Instagram
Autodesk Solutions Expert
Autodesk Certified Instructor
Message 8 of 11
HVAC-Novice
What resolution, Revit version and which windows?
Works for me with R2024.2 on W10 and 4K monitor.
Message 9 of 11
justin.jollyJ4XVN
As said earlier, in my case, the issue got resolved on restarting the computer. Could you please try the same once.
Message 10 of 11
Maksim.Melnikov.BY
Windows 10, Revit 2024, 3440x1440
Message 11 of 11
HVAC-Novice
Update to 2024.2
Update drivers and everything Windows
Does the snapping work for other application, or is Revit the only one being difficult?
