- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Revit 2019...
So one of the first things I created was a flow meter with instance parameters that allowed the flow meter to adjust to whatever pipe it connects to.
But now, all of a sudden, I try to place a pipe accessory, it wants to host to a level. And the family was never "work plane based" and still isn't.
If I click on System --> Plumbing and Piping ---> and "Pipe Accessory", you'll notice in the green placement ribbon, there's a pull down that looks at "Floor Level", and the options are the various levels of my project. It's ignoring the pipe.
This worked for 2018, and I even tried default "out of the box" pipe accessory stuff... Valves, etc... they all do this.
And that's a 3" line I was trying to connect it too, so it's not like I was trying to drop it into a pipe that was an unavailable size.
This example is an out of the box double check valve.
Anyone run into this?
¡Resuelto! Ir a solución.
