P-traps
P-traps
ben
P-traps
ben
Anyone know of a p-trap for Revit that can swivel at the joint of the st90 and the 180 like a real p-trap? Or are they all just fixed straight?
Revit lives in the land of perfect and doesn't understand what construction is.
Lev97
Hope this Video helps.................
ben
I was thinking more about having it swivel here
Like how p-traps can swivel in real life
so it can match up with things in the walls like washer boxes, where the pipe is centered in the wall the drain outlet on the fixture isn't. This would also be helpful on floor drains too
Lev97
....I see, Looks like you need a "Return Bend". Revit has a "Return Bend Medium-Pattern - Threaded - MI - Class 150.rfa" family you might want to try.....Good Luck.
ben
Thinking trap and st90 separate?
