Apologies for the question, I have just started using Revit.
The company I work at (public water company) has set a list of parameters that wants to see implemented in future projects. Those parameters are not in English.
Nevertheless, some of those parameters already exist in Revit in some way (e.g. dimensional parameters).
The lead designer is asking us if he can use revit parameters in those cases or if he should also create custom parameters as he is doing for those not present in Revit.
Is there any risk in loss of uniformity in using some Revit parameters in English and already set by the software and others in a foreign language and slightly different (e.g. COMPANY_parameter) ?
Thanks in advance!
Solved by HVAC-Novice. Go to Solution.
it might be a good idea to establish company shared parameters in any language.
this file is shared on a network drive for all Revit users to leverage
see link below
Note that the parameters have a unique identifier (you can see them in the txt file that holds the shared parameters). So if one is created you need to transfer that to other people. They can't just create a new one with the same name - those will have different identifiers and will be seen as distinct by Revit (but not by humans that only see the name).
I don't think you can rename shared parameters. Why not standardize on English names or what your main language is? Revit doesn't care if a name is English or Klingon. You can rename project parameters - but I'm not sure if they then truly still are the same. Renaming those works in the context of the same project. Not sure if that is true when you transfer them.
Good idea to name them in a specific way. I for example call all the shared parameters I create "SHARED_whatever". that way I always see which ones are mine, and which ones came from manufacturer families etc.
