- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi there,
I am a Project Engineer for a MEP sub-contractor (installer). I have acess to the Architectural, Structural and MEP Revit Files. I am in charge of creating coordination drawings on this project that has already been designed and engineered. Our scope of work falls under mechanical and plumbing. I was wondering what would be the best way to go about setting up a new Revit File in order for me to manipulate the MEP file so I can move things around that need to be coordinated with the other subs such as mechanical equipment, ducts, hydronic piping, plumbing piping and some electrical conduit and cable tray runs.
What I have started to do was opening the MEP file, since that is the one I need to be manipulating, and linking the arch and structure files. When trying to override the visibility and graphics of the two linked files, I can not manipulate any of the catagories because they are greyed out. I know this is a pretty broad description, but If anyone else has had this issue or has had this responisbility before, is there a better way than I am describing to go about setting up the new project?
Thank you for your time,
- Bil
