I'm trying to set up routing preferences to behave as follows:
If a pipe junctions into a larger pipe, a tap should be created
If a pipe junctions into a same-size pipe, a tee should be created
If a pipe junctions into a smaller pipe, a reducing tee should be created
If a pipe with an end-type of grooved junctions into a pipe, a grooved tap or tee should be created per the rules above
If a pipe with an end-type of threaded junctions into a pipe, a threaded tap or tee should be created per the rules above
Currently it seems like revit only allow me to drive routing based on sizes - not sizes driven by the two intersecting pipes and not by an end-type parameter. Is there any workaround?
would I have to create a parametric family that has a tap, tee, and reducing tee inside it, and use if-then conditionals to show the tap, tee, or reducing tee based on what its connected to?? seems extremely bad solution
Solved by fabiosato. Go to Solution.
Unfortunatelly, when it comes to choosing between tee or tap there are no automation available, you can:
1 - Create too pipe types, one uses too in routing preferences and another using tap.
2 - Whenever you need to use tee or tap, change the routing preferences before connecting.
Fábio Sato
What about
\Pipe\Fittings\Generic\Branch-Connection-Welded-Generic.rfa
