Revit MEP Forum
Revit - intelligent pipe taps?
2 REPLIES 2
i_am_fail
1290 Views, 2 Replies
I'm trying to set up routing preferences to behave as follows:
If a pipe junctions into a larger pipe, a tap should be created
If a pipe junctions into a same-size pipe, a tee should be created
If a pipe junctions into a smaller pipe, a reducing tee should be created
If a pipe with an end-type of grooved junctions into a pipe, a grooved tap or tee should be created per the rules above
If a pipe with an end-type of threaded junctions into a pipe, a threaded tap or tee should be created per the rules above
Currently it seems like revit only allow me to drive routing based on sizes - not sizes driven by the two intersecting pipes and not by an end-type parameter. Is there any workaround?
would I have to create a parametric family that has a tap, tee, and reducing tee inside it, and use if-then conditionals to show the tap, tee, or reducing tee based on what its connected to?? seems extremely bad solution
2 REPLIES 2
fabiosato
in reply to: i_am_fail
Unfortunatelly, when it comes to choosing between tee or tap there are no automation available, you can:
1 - Create too pipe types, one uses too in routing preferences and another using tap.
2 - Whenever you need to use tee or tap, change the routing preferences before connecting.
Fábio Sato
What about
\Pipe\Fittings\Generic\Branch-Connection-Welded-Generic.rfa
Ron Allen
Ware Malcomb Bim
