Revit Coordinate
Revit Coordinate
Revit Coordinate
Someone asked me to do what is written below because some things are twisted when bringing in a revit drawing to navisworks.  Not sure how to accomplish this:
"To get the structure to square up I had to change the coordinates to the opposite of what was default in the revit model (from shared to project internal)."
novesvalentin
Hi @Anonymous
Do you mean the way you insert a Revit link? if that is the case you can see in the image attach how to select that.Capture.PNG
Let me know how it goes
If this helped solve your problem please mark it as solution, so other users can get this solutions as well.
Valentin Noves
BIM Manager
www.valentinnoves.com
Valentin Noves
BIM Manager
It is an existing Revit Drawing where the BIM coordinator is telling me when they pull it into Navisworks, the drawing is rotated.  They sent me the original request as a solution.
novesvalentin
Hi @Anonymous,
I get it now. You have to follow the steps below to select Shared or internal in the way that you export your file to navisworks:
Valentin Noves
BIM Manager
Valentin Noves
BIM Manager
