Revit 2020 Language Change
hannah.pierceSY4CK
hannah.pierceSY4CK
When opening Revit 2020, the language has changed itself. The Revit properties>shortcuts dialogue box already shows ENU but this isn't reflected in the model. Any help is appreciated - thank you!
iainsavage
Do you mean that when you enter data in English the model changes it to a different language?
Or do you mean that items already in the model are in a different language?
Could you post some screenshots or upload the model?
hannah.pierceSY4CK
The language overall has changed. Here is a screenshot~
iainsavage
On the windows desktop if I right-click the Revit icon and select proprties the target path is:
"C:\Program Files\Autodesk\Revit 202x\Revit.exe" /language ENG
where x is 1, 2 or 3 depending on which of my installations I look at, but I'm using UK English.
In your case it should probably be:
"C:\Program Files\Autodesk\Revit 2020\Revit.exe" /language ENU
Is that what you have?
hannah.pierceSY4CK
Thank you for the reply. Unfortunately that fix isn't working for us - the file path already includes "ENU" in the language area.
iainsavage
If you have support from Autodesk or a reseller it might be worth raising a ticket for this one.
Or do a clean uninstall and reinstall to see if that works.
