Adding a label to a perameter within a tag
MIlieuCADWin
MIlieuCADWin
Hi I,m Simon
I,m sure you can do this, but not sure how,
I want to add a text label to a duct parameter Tag, ie 350x350 EXH DUCT (a piece of text) - but the text must be instance and not change on every tag - like the last Revit Guru did
Any advice will be much appreciated
Add Comments parameter to the label.
RobDraw
You can add a parameter to a label that reads the system abbreviation and add "DUCT" as a suffix.
Rob
