Revision Cloud Style
ToddKubicek
Message 1 of 13
ToddKubicek
Is there a way to change revision cloud thickness and color? I understand how to change this on simple lines but for some reason I can not make changes to the clouds.
Thanks!
Replies (12)
Message 2 of 13
Yes, go to Visibility Graphics "VV" or "VG". Click the Object Styles button near the bottom. Click the Annotation Tab at the top. Scroll down to Revision Clouds and there you can change the lineweight from 1 to whatever to get your thickness, you can also change the color there too.
Message 3 of 13
Message 4 of 13
ToddKubicek
Seems to easy but worked great! Thanks!
Message 5 of 13
The previously mentioned solution is a quick fix and will get the job done but... If you change it in the object styles tool in the manage tab then this will apply to the whole project as opposed to the individual vew/sheet visibility graphic overrides. I find this to be much more usefull as I imagine you dont want to have to change this each time you place a cloud. ope that helps.
Message 6 of 13
smbrennan
If you read the previous comment all of the way through, the user specified to use the shortcut link WITHIN Visibility Graphics to take them to Object Styles. But you are correct, it's always preferred to change lineweights and styles within the Object Styles menu (and not the Visibility Graphics Override Menu).
Shawn B.
To help improve Autodesk Products, please Click Here to Vote for ideas and submit your own.
Message 7 of 13
what do you do if you want revision clouds of different colours. i.e. a cloud for clash notes and a cloud for revisions and don't want to have to do one of them every time you do a cloud? We can make different text types, why not revision clouds?
Message 8 of 13
RobDraw
Then they wouldn't be revision clouds, they would be annotation clouds. Maybe you should suggest that over in the ideas forum.
Rob
Message 9 of 13
Hi..Is there is any way to change Revision Cloud type,,i.e, I don't want that default arc type ,i want to create a new one.Is it possible...?And, I'm not asking to change Arc Length..I want new arc type in rev. cloud..
Message 10 of 13
RobDraw
No, you can't change the style.
Rob
Message 11 of 13
Ok,thanks..
Message 12 of 13
308LLC
Observer
Observer
The Object Styles was very helpful, but is there any way to make the clouds transparent other than VG settings?  I really like a thick line that's about 50% transparent so they're easy to find, but you can still see what's going on behind them.  Anyone have any luck with this?
Message 13 of 13
s.borello
Manage_Object Styles will let you change it globally for all views... VG will let you change it for that view only.
