Reorder the way parameters appear in the properties box
Message 1 of 26
Hi, I have created some new parameter's but they dont appear the way I want them to in the properties box.(see attached) they are all in the Text part of the properties just not in the order i need. Is it possible to reorder them in Revit or is there an addon that will do it??
Replies (25)
Message 21 of 26
N.Tran_Mazzetti
Observer
Observer
Hey Maria! Did you ever find the solution to this 'glitch'? I accidentally did the same and hated it, but have also realized a use for it...so now I don't want to lose it.
Message 22 of 26
davidjimm
What was the name of the add-in? I'm interested.
Message 23 of 26
CEdwardsUN5MX
Based on how many issues last for the incredible number of years since people ask for something to be fixed (now 8 years since the original post in this thread!) it's pretty clear that Autodesk expect us to be programmers first, earning an income second.
Message 24 of 26
adriansin_randalllamb
This is true. You must use Dynamo to delete the shared parameter. Once you re-add the parameter to the project again it will have a new ID and it will reorder itself to the bottom. See attached Dynamo Script to delete one parameter. Please use with caution.
Message 25 of 26
curtisridenour
If you are working with a Template, be very careful about what Parameters you strip out. They are imbedded within View Filters, Schedules and Families. You will want to pull all 3 of those things back in after removing the shared parameters via Dynamo by ID number.
Message 26 of 26
Haseeb_Hanan
Community Visitor
Community Visitor
You can fix this using Diroots' "ParaManager" tool. Here’s how:
  1. Open Diroots Paramanger (you’ll find it in the Revit Add-Ins tab).
  2. Export your current parameters to an Excel file.
  3. In the Excel file, just rearrange them in the order you want.
  4. Go back to Revit and delete the old parameters (so there’s no duplicates).
  5. Finally, import the updated Excel file using Paramanager and hit Apply
