Problem with import xml file in HAP
konticv
konticv
I have a problem with importing an XML file from Revit to HAP. When I try to import an XML file from Revit into HAP I get a notification that: 1. the file does not contain any spaces data, 2. is not formatted according to the gbXML schema, 3. does not contain XML. The same happens when I export an existing one from Revit basic simple project
iainsavage
Your post looks like this, more details are needed.
konticv
I have solved the problem.
mahyar.niroumand
Community Visitor
Community Visitor
How
alancvct
Certifique-se de criar “Spaces” analíticos no template MEP pelo menu Analyze > Energy Settings, exportar sempre via File > Export > gbXML (renomeando para .gbxml) e validar que o arquivo contenha tags <Space> antes de importá-lo no HAP.
