I'm at my wits end and need some assistance!
We're currently running Revit 2019.2.2 and have connected to an accelerator server via Collaborate > Manage Connection to a Revit Server Accelerator, and now we need to disconnect from it.
We've completed a full, clean install of Revit 2019, following the Autodesk clean install guides including removing all relevant folders, all 2019 Revit products, addins registry keys, everything.
However, upon reinstalling Revit 2019 is still connected to the accelerator server. We cannot find anywhere that contains this info and so we're stuck connected to it.
We've also checked the Windows Environment Variables and the RSACCELERATOR2019 variable doesn't exist. We attempted to add it manually and remove it, but nothing.
Note that we do have other Revit versions and Autodesk products installed, however none of these are connected to an accelerator.
Currently running Windows 10 Pro.
Your help is greatly appreciated! Thank you!
