- Mute
- Permalink
- Report
Hi all,
Is there a way to disconnect the shared parameter from a project?
This is my situation:
I have a basic project with families built in a shared parameter file with version 2.5.
The file is from the NLRS (Dutch Revit Standard).
Now the file has been changed over time and 3.0.1 is now used.
The name of some parameters are changed, but the GUIDS are the same.
Revit gives me a warning when I load a family with lookup table (family is build in 3.0.1).
This is because the parameter has not been found.
Some how the project is still connected with version 2.5
Is there a way to disconnect the shared parameter file from cache?
KG,
Jan Willem
Link copied
