Revit MEP Forum
Remove shared parameter from cache?
3 REPLIES 3
jw.vanasselt
232 Views, 3 Replies
jw.vanasselt
Hi all,
Is there a way to disconnect the shared parameter from a project?
This is my situation:
I have a basic project with families built in a shared parameter file with version 2.5.
The file is from the NLRS (Dutch Revit Standard).
Now the file has been changed over time and 3.0.1 is now used.
The name of some parameters are changed, but the GUIDS are the same.
Revit gives me a warning when I load a family with lookup table (family is build in 3.0.1).
This is because the parameter has not been found.
Some how the project is still connected with version 2.5
Is there a way to disconnect the shared parameter file from cache?
KG,
Jan Willem
Hi all,
KG,
Jan Willem
3 REPLIES 3
mikewp90
in reply to: jw.vanasselt
mikewp90
You need to select the ID of the parameter in order to delete it from the model. You are able to select it by using dynamo. SelectbyElementTypes > FilterByName > GetElemementIDs from selection.
fabiosato
fabiosato
If you use DiRoots plugin to remove the parameters, they are removed from the database.
Fábio Sato
Fábio Sato
jw.vanasselt
jw.vanasselt
Hi @fabiosato  & @mikewp90 ,
Sorry for the late response.
Thanks for the tips, I will try this.
