Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Reducing elbow swept edge blend line not align
14 REPLIES 14
Message 1 of 15
pe_simon
467 Views, 14 Replies
pe_simon
I create it by  elbow swept. Thanks.
14 REPLIES 14
Message 2 of 15
in reply to: pe_simon
If it is a 90 degree elbow then the path must be a quarter of a circle.
Message 3 of 15
pe_simon
in reply to: ToanDN
pe_simon
It is a reducing elbow 50mm x 25mm, how can I fix it?
Message 4 of 15
fabiosato
fabiosato
If you can share your family, it will help us to help you.
Fábio Sato
Fábio Sato
Message 5 of 15
pe_simon
in reply to: fabiosato
pe_simon
Okay,  sure.   A must 43mm, B must be 50mm. Others can change. Thanks a lot.
Message 6 of 15
Like this?  If so, see attached Revit 2002 family (I don't have 2020) and you can replicate it in your original 2020 file.
Message 7 of 15
pe_simon
in reply to: ToanDN
pe_simon
Can not open revit 2002 version file...
Message 8 of 15
dyp4f
dyp4f
Message 9 of 15
pe_simon
pe_simon
Who can update it from revit 2009?  And then I try to update it to 2020 from version 2009.
Message 10 of 15
dyp4f
dyp4f
You can easily fix your family by yourself.
Just do the following:
Go to Family Editor
--> tab: Ref.Level
--> select the Swept Blend
--> press “Edit Swept Blend”
--> press “Sketch Path”
--> select the magenta line representing the Sketch Path
--> you will see a tiny circle (near the middle of the path) that is slightly off axis
--> drag it to the dead center of the reference lines cross
--> press the green "check" , and "check" again
--> your family is OK and aligned
Go to Family Editor
--> tab: Ref.Level
Message 11 of 15
It's Revit 2022, not 2002 (typo). If you cannot open it, then you can fix your file yourself by re-drawing the swept blend path as a quarter of an ellipse, which sets the profile 1 and profile 2 planes align with their target ref planes, and that should be it.
Message 12 of 15
pe_simon
in reply to: ToanDN
pe_simon
Thanks, done it but not same as your figure??
Message 13 of 15
pe_simon
in reply to: dyp4f
pe_simon
Where can find the magenta line??
Message 14 of 15
Sorry the quarter ellipse should be between the inside faces of the two rings.
Message 15 of 15
pe_simon
in reply to: ToanDN
pe_simon
Fixed, Thanks!
Fixed, Thanks!
