It is a reducing elbow 50mm x 25mm, how can I fix it?
If you can share your family, it will help us to help you.
Fábio Sato
Okay, sure. A must 43mm, B must be 50mm. Others can change. Thanks a lot.
Like this? If so, see attached Revit 2002 family (I don't have 2020) and you can replicate it in your original 2020 file.
Can not open revit 2002 version file...
Who can update it from revit 2009? And then I try to update it to 2020 from version 2009.
You can easily fix your family by yourself.
Just do the following:
Go to Family Editor
--> tab: Ref.Level
--> select the Swept Blend
--> press “Edit Swept Blend”
--> press “Sketch Path”
--> select the magenta line representing the Sketch Path
--> you will see a tiny circle (near the middle of the path) that is slightly off axis
--> drag it to the dead center of the reference lines cross
--> press the green "check" , and "check" again
--> your family is OK and aligned
It's Revit 2022, not 2002 (typo). If you cannot open it, then you can fix your file yourself by re-drawing the swept blend path as a quarter of an ellipse, which sets the profile 1 and profile 2 planes align with their target ref planes, and that should be it.
Thanks, done it but not same as your figure??
Where can find the magenta line??
Sorry the quarter ellipse should be between the inside faces of the two rings.
