- Mute
- Permalink
- Report
Hey everyone,
I'm currently working on creating a Revit family for a rectangular duct elbow, and I'm encountering some challenges. Here's the situation:
I need the elbow to have different widths and heights on the two connections. The inner and outer radii of the bend should be manually input by the user, and the elbow should adjust accordingly.
I'm only creating solid geometry, without using voids, and I want to ensure the geometry respects the inner and outer radii.
The problem I'm facing is getting the sweep blend to correctly transition between the two profiles (Width1 x Height1 to Width2 x Height2) along the arc of the elbow while maintaining the correct inner and outer radii.
I'm struggling with how to define the arc path and constrain the sweep blend to ensure the elbow adjusts as needed. Any advice or step-by-step guidance would be greatly appreciated!
Thanks in advance!
