Revit MEP Forum
"... disconnect ..." Error message when group of pipes copied to other levels
9 REPLIES 9
Message 1 of 10
sakar_deepak
529 Views, 9 Replies
sakar_deepak
Hi all,
When I copy a 'group' of pipes, fittings and plumbing fixture to upper levels, an error message " Elements need to be disconnect" pops up . It disconnects all type of elements ... pipes, fittings and plumbing fixtures.
Why is it happening and what is the solution  ?
Attached are RVT file and screen shot of error message.
Regards
Deepak Gupta
Architect
(...... those, who are answering the problems in community forum here, are great people .....)
Hi all,
Regards
Deepak Gupta
Architect
9 REPLIES 9
Message 2 of 10
fabiosato
in reply to: sakar_deepak
fabiosato
One suggestion is to include the piping systems to the elements before making a copy.
Fábio Sato
Fábio Sato
Message 3 of 10
sakar_deepak
in reply to: fabiosato
sakar_deepak
Thanks for the reply.
But it pops up error message again.  " .....selected items will not be included in group ... "
Revit does not allow grouping of piping system.
Attached is screen shot of error message.
Regards
Deepak Gupta
Architect
Regards
Deepak Gupta
Architect
Message 4 of 10
sakar_deepak
sakar_deepak
.....And, if i do the otherwise, that is, select group and then select piping system together to copy on other levels .... it greys out the copy clip icon. It cant copy clip.
Regards
Deepak Gupta
Architect
Regards
Deepak Gupta
Architect
Message 5 of 10
sakar_deepak
sakar_deepak
@fabiosato
Any help ?
No body seems to be having solution for this.
Is it ?
Regards
Deepak Gupta
Architect
@fabiosato
Any help ?
Is it ?
Regards
Deepak Gupta
Architect
Message 6 of 10
fabiosato
fabiosato
Usually I use the save selection to copy, groups does not work well with MEP.
Fábio Sato
Fábio Sato
Message 7 of 10
sakar_deepak
sakar_deepak
Checked all errors one by one. It almost disconnected all pipe fittings and floor drains.
Any idea, what to do to get answer from Autodesk directly ?
Regards
Deepak Gupta
Architect
Regards
Deepak Gupta
Architect
Message 8 of 10
RobDraw
RobDraw
Have you tried pasting to current or selected levels without using groups?
Rob
Rob
Message 9 of 10
sakar_deepak
in reply to: RobDraw
sakar_deepak
Yes, with out group, it works fine.
But, i want to do it in group because there are 9 levels. Group will help making revisions.
Regards
Deepak Gupta
Architect
Regards
Deepak Gupta
Architect
Message 10 of 10
fabiosato
fabiosato
If you want to you groups, this is the normal behaviour... unfortunatelly.
Fábio Sato
Fábio Sato
