Revit MEP Forum
pure unuse pipe segment
3 REPLIES 3
youssef.ibrahimM37J6
206 Views, 3 Replies
any way to purge unuse pipe segment which is not use in any pipe rounting prefernces ?
3 REPLIES 3
Assume you mean purge?
You can delete them, you'll get a warning if its in use:
You can also use a schedule to identify which ones are used in your pipe types but you need to place at least one pipe of each type in the model in order to get the schedule to populate:
thank you @iainsavage
Forma Design Contest
