The connectors in each pump must be set to System, them you can set for each the fraction of the total flow the will correspond to each pump, let´s say pump 1 get 0.6 and pump 2 get 0.4. In the small button on the right you can link a parameter, so you can adjust the value easier, I suggest to use a instance parameter.
Fábio Sato
