Revit MEP Forum
Problem with import CAD and explode (disappear object)
6 REPLIES 6
marco.defina
1850 Views, 6 Replies
Hello, i have a problem with insert CAD in a family.
In the video below it can see: if i explode the element in 1 scale work fine, if i scale after i explode i loose some pieces.
If i scale in autocad and then i import happens the same thing. If as Revit can see little pieces.
It's a solution? for exaple scale after explode? (but don't work)
BIM Manager - HVAC and Plumbing designer https://www.autodesk.it/content/dam/autodesk/www/products/responsive-imagery/responsive-badges-compare/2019/navisworks-manage-2019-badge-75x75.pngApp AutoCAD per dispositivi mobili premiumNavisWorks Simulate3ds Max___________________________________________________________________________
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums.
6 REPLIES 6
CoreyDaun
in reply to: marco.defina
Unfortunately, it is like the case that those elements are too small and complex for Revit to create them; Revit is not very compatible with tiny, detailed objects. Perhaps the solution is to find a way to avoid the need to explode it? There's not much I can give in the way of advice, here, sorry to say.
marco.defina
in reply to: CoreyDaun
If i don't explode i cannot set a material to the component...exist any different way to make this?
fabiosato
Hello Marco,
Just as a reference 0.8mm is the minimum length revit can handle for a line.
Maybe using the AutoCAD you can create solid to represent the item you need.
But remember not to try to model very tiny pieces.
Fábio Sato
marco.defina
in reply to: fabiosato
Ok i will modify the file with autoCad and.
fabiosato
Hello Marco,
Just one question, this level of detail is absolutelly necessary? If not, you could try to simplify it.
If you need this level of detail using Inventor will be an option.
Another option for modeling is to use the 3D CAD as reference and you create the solids on Revit.
In the family editor, when you import a CAD file, you increase the file size with some items, for example, Line types, I recommned you to clean them before using in a project.
Fábio Sato
marco.defina
@fabiosato wrote:
Hello Marco,
It's not necessary but is fast, i take the model from the productor website and I import (i cannot everytime remake al solid of every equipment). Here i have no inventor installed to reduce the detail.
Yes i clean everytime, thanks.
Forma Design Contest
Technology Administrators
