Problem with halftone
dirk_h
Message 1 of 8
dirk_h
I have following problem with the halftone option :
I've linked an architectural model to a MEP model as underlay. When I check in "visibility/grafics" -> "Revit Links" the option "halftone" and "underlay", not only the linked model but also the duct-fittings and the air terminals change to halftone (ducts are OK). This is not my intention. How to solve this?
Thans in advance!
Dirk
Replies (7)
Message 2 of 8
RobDraw
This shouldn't be happening to the fittings.
Take a look at the V/G settings for the fittings and the terminals.
Can you please post a portion of the model that exhibits the behavior?
Rob
Message 3 of 8
dirk_h
Hey, Thanks, I think it is solved by reloading the model. But a problem appeared ; 1) an orange line appears on the architectural model in MEP. It seems to be the contour of the floor/roof???
Message 4 of 8
hi, set you link by custom and change the parameter to see where it is come from
or set the like by liked view
Message 5 of 8
dirk_h
"or set the like by liked view"......Sorry but I’m afraid I don’t follow you. The yellow boundary (floor/roof???) line is still there.
Message 6 of 8
RobDraw
It looks like a slab edge but you need to determine what it is by doing a tab select on it or by opening the architectural model.
Rob
Message 7 of 8
dirk_h
It seems to be a generic foor... see attachment
Message 8 of 8
disable the analytics
