Problem with halftone
dirk_h
dirk_h
I have following problem with the halftone option :
I've linked an architectural model to a MEP model as underlay. When I check in "visibility/grafics" -> "Revit Links" the option "halftone" and "underlay", not only the linked model but also the duct-fittings and the air terminals change to halftone (ducts are OK). This is not my intention. How to solve this?
Thans in advance!
Dirk
Replies (7)
RobDraw
This shouldn't be happening to the fittings.
Take a look at the V/G settings for the fittings and the terminals.
Can you please post a portion of the model that exhibits the behavior?
Rob
dirk_h
Hey, Thanks, I think it is solved by reloading the model. But a problem appeared ; 1) an orange line appears on the architectural model in MEP. It seems to be the contour of the floor/roof???
hi, set you link by custom and change the parameter to see where it is come from
or set the like by liked view
dirk_h
"or set the like by liked view"......Sorry but I’m afraid I don’t follow you. The yellow boundary (floor/roof???) line is still there.
RobDraw
It looks like a slab edge but you need to determine what it is by doing a tab select on it or by opening the architectural model.
Rob
dirk_h
It seems to be a generic foor... see attachment
disable the analytics
