Problem to create local file
HEETESHC
HEETESHC
I am facing an issue with my Revit software 2018, 2017, 2016 & 2015 as well and to overcome this I tried to re-install the whole software package.
the problem is that all the Revit users in the office are able to open their central files simply by using the option "create new local" command that appears on the screen however on my machine this option doesn't allow you to opt that option(fades out / we can say unfocused). image attached for more clarification.
ASCunningham
I would say that the file you have has not been created as a central file yet. Until you do this you cannot create a local copy.
Go to the Collaborate tab and select the collaborate button.
Check your local folder see if it exists and you have the right to write to it. Switch to another folder and see if it makes any difference.
J.Wehmer
Are you possibly using a Revit 2018, to try and open a Revit 2017? If you try to open an older version, even though it may be a central file. You cannot create a local copy unless it is of the same version. If you try to open a R17 project in a R18 program, it will not give you the "Create Local file" option until the model us upgraded, and resaved as a Central Model.
-Please click accept as solution if this answers your question!
Matt__W
@HEETESHC have a look at this AKN article for a possible solution.
CREATE NEW LOCAL CHECKBOX IS DISABLED IN REVIT
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Big R in left hand corner > Options > File Locations > path for local files.  All of our users have this problem when the software is updated because the default file location is for our corporate software license manager.
