Printing to PDF with Hidden Lines OFF, still showing hidden lines
Trevit_Hicks
Trevit_Hicks
I am trying to print some drawings from Revit using the Bluebeam driver, but the function that hides the hidden line (to replicate how we show pipe in AutoCAD) is only in the program screen, not in the PDF print out. I have tried all the other options in the view template, including a white Revit material to MEP Fabrication Pipework... Is this an issue with the Bluebeam driver or is it Revit not having correct functionality?PDF  showing hidden linesPDF showing hidden linesRevit screen blocking hidden linesRevit screen blocking hidden lines
RobDraw
How are you turning off hidden lines? Switching display settings, V/G overrides, switching off MEP hidden lines?
Are you using lines merge or lines overwrite in the PDF settings?
Rob
Trevit_Hicks
Looked for MEP Hidden Line, didn't know that option existed! That fixed it, it seems. I tried all the overrides, and view template adjustments, but it was the MEP Settings in Mechanical that fixed it
