Hi All. Using Revit 2023 -
I cannot assign a 480V primary distribution system to my single phase transformer.
My connector (in the transformer family) is 2-Pole, 480V. I'd think I can assign it to the 480V distribution system, but there's no option to do so.
I can change the connector to be 3-Pole, but then the primary breaker will also be 3-Pole when it's powered up (it needs to be 2-Pole).
I've included the family and the distribution systems I have set up in case that's the problem. Thanks in advance -
Solved by fabiosato. Go to Solution.
You can try this setting in the distribution system
And this setting in the transformer
Fábio Sato
