Pipetype Field overlapping Size field
andkal
andkal
Hello
I have such a annoying problem: one field is overlapping the field with Pipesize., and its position is fixed.
Whereas when I open a sample Revit project from Autodesk this field is gone. I suppose it is somehow embedded in my project.
What can I do with it to turn it off?
• www.autolisps.blogspot.com - Productivity plugins for Autocad and Autocad MEP
• Autodesk AppStore
hmunsell
Give this a try.... these instructions are for resetting the Project Browser, but it should reset all the tool windows and pallets.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/CloudHelp/cloudhelp/2020/...
Howard Munsell
andkal
I updated to version 2022 and still the same problem.
Nevertheless your solution partially helps. When I reset settings this field is gone. But after some time of work it appears back. So I reset settings each  time before starting revit.
• Autodesk AppStore
