Looking for a solution to fix a sanitary tee being added in wrong direction. When I click the + sign to added a tee, it adds the tee in the wrong direction. Also, if I try to draw a pipe coming off the original pipe, it adds the tee in the wrong direction. Does anyone know a solution to fix the family?
Unfortunately the family is not properly done, the end pointing up in the family should be pointing down.
To fix the problem, it will be necessary to fix the orientation of this end.
Fábio Sato
As this family was supplied by the manufacturer, they should be informed to do so.
The other option is for you to correct it by yourself, unfortunately, there is a lot of bad content on the web.
Fábio Sato
Do you know how to edit families? Or create them?
Fábio Sato
