Revit MEP Forum
Pipe Tee Getting Added in Wrong Orientation
7 REPLIES 7
Message 1 of 8
zcorcoran
958 Views, 7 Replies
Looking for a solution to fix a sanitary tee being added in wrong direction. When I click the + sign to added a tee, it adds the tee in the wrong direction. Also, if I try to draw a pipe coming off the original pipe, it adds the tee in the wrong direction. Does anyone know a solution to fix the family?
7 REPLIES 7
Message 2 of 8
RobDraw
in reply to: zcorcoran
Post the family.
Rob
Message 3 of 8
zcorcoran
in reply to: RobDraw
See attached
Message 4 of 8
fabiosato
Unfortunately the family is not properly done, the end pointing up in the family should be pointing down.
To fix the problem, it will be necessary to fix the orientation of this end.
Fábio Sato
Message 5 of 8
zcorcoran
in reply to: fabiosato
@fabiosato And how do I fix the orientation?
Message 6 of 8
fabiosato
As this family was supplied by the manufacturer, they should be informed to do so.
The other option is for you to correct it by yourself, unfortunately, there is a lot of bad content on the web.
Fábio Sato
Message 7 of 8
zcorcoran
How do I correct it myself?
Message 8 of 8
fabiosato
Do you know how to edit families? Or create them?
Fábio Sato
State of Sustainability Webinar
