How to change the system type of the pipe. Right now the system type im working is other and i want to change it to hydronic supply. Attached is my situation right now. I click already all the pipes but how come only the current system of pipe is showing, there is no choices to change the system type.
Solved by berniebooc. Go to Solution.
I don´t have sure. But on the top if you have the pipe selcted does not appear "pipe system" in a green shade? On the rigth side of the modify pipes?
Here you can edit the system.
Is a little help. I don´t know if it is a solution for you.
cheers
cheers
you should be able to change the system type from the properties palette under mechanical (see attached). just select one straight pipe connected to the system.
thank you so vbm76 for your help. I found the solution already..
