Revit MEP Forum
Pipe System Pipe
5 REPLIES 5
berniebooc
580 Views, 5 Replies
Pipe System Pipe
berniebooc
How to change the system type of the pipe. Right now the system type im working is other and i want to change it to hydronic supply. Attached is my situation right now. I click already all the pipes but how come only the current system of pipe is showing, there is no choices to change the system type.
Pipe System Pipe
5 REPLIES 5
in reply to: berniebooc
I don´t have sure. But on the top if you have the pipe selcted does not appear "pipe system" in a green shade? On the rigth side of the modify pipes?
Here you can edit the system.
Is a little help. I don´t know if it is a solution for you.
cheers
cheers
bvm76
bvm76
you should be able to change the system type from the properties palette under mechanical (see attached). just select one straight pipe connected to the system.
Please mark Accept as Solution if your question is answered!
Thank You.
Thank You.
berniebooc
in reply to: bvm76
berniebooc
bvm76 still the same only other and no other choices to choose when I select one straight pipe as you suggested.
bvm76
bvm76
Is it possible to upload the revit file?
Thank You.
Thank You.
berniebooc
in reply to: bvm76
berniebooc
thank you so vbm76 for your help. I found the solution already..
