Revit MEP Forum
pipe double insulation
2 REPLIES 2
eslam_r_abdallah
265 Views, 2 Replies
Is it available to add double insulation for pipe in REVIT 2016  ??
I have searched for method to do this  but did not found any method to do this
Thanks in Advance
2 REPLIES 2
in reply to: eslam_r_abdallah
You are right
There is no such provision to add double insulation for pipe in REVIT.
double the insulation thickness
if by default it may be 1" change it to 2"
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Forma Design Contest
