Pipe break when sanitary pipe below fixture
Hi everyone,
My sanitary pipe below a bathtub is breaking for some reason. I have played with the MEP hidden line settings as well as with other hidden line settings with no luck in fixing it. attached is a picture of my problem. Any help would be great.
Thank you,
To me it does not look broken. It looks like there´s a T fitting after the bathtub connector and the the pipe.
Try modifying the visibility in the T familiy.
our office have same issue, you can solve it by following steps :
1. select the fitting.
2. at properties palate, graphics tab you can un-select use annotation scale or select annotation scale.
hope that's can help.
