Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Revit MEP Forum
Phasing controls across Revit Links
3 REPLIES 3
Stephm419
300 Views, 3 Replies
I have an MEP project.
The workflow is as such, the "existing to remain duct work" needs to be a dashed line in the new construction view.
The wall are in the Linked Revit files.
I need all walls (New and Existing) to be viewed as solid lines.
Please see attached files. I am using Revit 2016.
3 REPLIES 3
S.Jebakumar
in reply to: Stephm419
Hi @Stephm419,
The required graphics is achieved just by adjusting the Graphic Overrides in Phasing please refer to the images.
also if you want to control Graphics Overrides for Arch and MEP separately,
you can achieve by performing Graphic Overrides in individual models and
controlling the views using Revit Link By host/By Linked view.
Jebakumar
BIM Specialist
Tags (1)
Stephm419
in reply to: S.Jebakumar
Which Project did you make the overrides.
Also, were the links all set to "Host View"?
I appreciate your help
S.Jebakumar
Hi @Stephm419,
I made the overrides in Mep New.
yes the links are by Host view. Refer the attached image.
Jebakumar
BIM Specialist
