Revit MEP Forum
Panel schedules
12 REPLIES 12
Message 1 of 13
elham.calm
1617 Views, 12 Replies
Panel schedules
Hello
when I created Panel schedule ,it is created but it was empty schedule, I don't know what do I do
please help me
12 REPLIES 12
Message 2 of 13
robert.klempau
in reply to: elham.calm
Hello @elham.calm,
What do you see?
can you upload a picture?
Did you place electrical objects and added them to your panel (Electrical Equipment)
Did you add a distribution system to your panel?
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
Message 3 of 13
elham.calm
in reply to: robert.klempau
Message 4 of 13
elham.calm
@robert.klempau : this pic show my problem
Smiley Sad
Message 5 of 13
It looks like you used a severely underdeveloped panel schedule template.  If the OOTB version isn't still in your model, you'll need to edit the template to give it the appearance and contain the information you want, then apply it to your schedule.
I also can't tell from the screencaps whether or not your circuits have been created and connected to the panel in question.  Revit will automatically populate the panel schedule fields for you, but you still have to create circuits and connect them to the panel.  To do this, you must first assign a distribution system to the panel.  Select the panel, and you'll have a drop down option on the ribbon called "Distribution System".  Select the correct choice from the list.  Once that's done, you have to connect the circuits.  Select the circuit itself, or any element belong to it, choose "Edit Circuit", then choose "Select Panel" and pick the required panel from the list.  Lather, rinse, repeat throughout your project.
Message 6 of 13
elham.calm
I created circuit and selected panel
I dont know, I tested every way but it was empty schedule , Would you take pic from one simple circuit that you creat panel schedule ( step to step ) ? Please help me🙏🏼
Message 7 of 13
stever66
Your panel schedule should look like this when you start:
Select the panel and pick "Edit Panel Schedule" from the ribbon.  Then pick "change template".  Hopefully, you still have the basic panel template in your project.  If you do select it.
If not, I suggest you start a new project using the default electrical project template.  Then create a panel and a schedule, and give it a test run.   If that works, you can go back to your project, select "manage" on the ribbon panel, and select "transfer project standards" to import a working schedule.
Also, I assume your panel has more than 0 spaces.  YOu might check that in the panel properties also.
Message 8 of 13
robert.klempau
Hello @elham.calm,
Did the solution @stever66 provided you solved your problem?
Please let us know
If it does please accept it then as a solution.
Kind regards,
Robert Klempau
Cadac Group AEC BV
Message 9 of 13
elham.calm
Hello @Anonymous
I did step to step but I had that problem and my schedule was empty again
Message 10 of 13
elham.calm
thanks @stever66
at last it was ok👍🏽
Message 11 of 13
Can you please explain
what is A B C and why?
I didn't understand
Message 12 of 13
In this pic
In between three columns are there in panel schedule
Message 13 of 13
It would be better if you create a new topic.
It corresponds to the name of each phase of the distribution system.
Fábio Sato
