Orient to Plane not working as usual
Radish_G
Radish_G
Hello everyone.
When I try to "Orient to Plane," it usually orients to the incorrect side.
If anyone has a solution to this problem, please share it.
Please see the attached video for a closer look.
Thank you in advance.
Regards
Radish G
robert.klempau
Hello @Radish_G ,
What do you want to achieve here?
your video shows that you are trying to set a workplane in a 3D view.
please see:  Set the Work Plane of a View
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
Mahmoud.Ziedan
@Radish_G
Sometimes when the workplace is a curved face, it will not be selected.As mentioned by @robert.klempau please let us know what you are trying to do!! and what is this face that you are trying to pick!!
You found a post helpful? Feel free to give it a like!
Your question got successfully answered? Click the 'Mark as Solution' button.
Mahmoud Zeidan
BIM Manager / Mechanical Engineer
Radish_G
Hi @robert.klempau & @Mahmoud.Ziedan ,
I am trying to set a plane normal to the current view.
Usually while we pick a plane to set it normal to the current view, the view will be oriented to the plane we picked. Here it's working in the other way around.
In the video, I am trying to set the view normal to the front face of the thermostat (The small Rectangular box hosted on to the vertical face) But, what I get is the rear face of the thermostat set normal to the current view.
I attached few screenshots for reference.
Regards
Radish G
Mahmoud.Ziedan
@Radish_G
I believe it is due to the face of the thermostat....the way the family was modeled affects the faces on the project.For instance, if the face was created by revolving it will not be selected. ( I know this is not your case but just an example)
Anyway, try to pick the wall parallel to the thermostat I think you will reach what you want.
Please if this solves your issue mark it as a solution to help others.
Mahmoud Zeidan
miklos.martonJGZBC
@Radish_G
As Mahmoud said, the orientation of the element might affect which way you're going to look at it after you've picked a face on it.
However, you can get around this issue by setting the Front of your 3D view to the new orientation in the context menu of the view cube. Then you'll be able to rotate the view around by exactly 180 degrees.
Radish_G
HI @Mahmoud.Ziedan & @miklos.martonJGZBC
It might be those reasons you mentioned, And I do think that it's because of the curved edges of the element.
But anyway it's a common problem not related to this particular element. It happens to the flat face like wall as well.
And I do strongly believe that it might be because of some bugs in the software.
Regards
Radish G
